View Poll Results: Which would you go with for a street suspension?
Qa1 coilovers
4
10.81%
Bilstein/Eibach
11
29.73%
Strange coilovers
3
8.11%
Other
19
51.35%
Voters: 37. You may not vote on this poll
2001 WS6 Street Suspension
There's a reason that combo is so popular. It's been proven time and time again.
I run Sam's springs, bars, Koni's, Watt's and a bunch of UMI stuff.
Sometimes it seems that people refuse to use the strano/koni setup. i don't know if it's because some people just want to be different or are new to the boards.
I was looking up these when I came up with that price.
LS1TECH Sponsor
I hear this at least once a week. I don't get it. AS for who gives you better price, I really hope that isn't the only criteria. You are getting different products with different experience behind them.
__________________
94LS1B4C those from summit are double adjustables(DA) you really only need (SA) single adj
I also voted other....see sig for a great street set up and worth every $$. Cool part is you can build a great street performer suspension in stages. Only thing you NEED to intall togther is your front shock/spring package cause you only want to take it apart once. The rear install is cake.
But remember the shock/spring combo is the same as a good head/cam package they need to work well together. Sam developed his springs using Koni's,that's why they work so well togther. Add a set of his Hollow Sways and your golden.
LS1TECH Sponsor
See, the idea that you need DA's and all that is why you want to call me and talk things over. I will be glad to talk over the differences and why I think in most cases, DA's are not necessary. Even if they were, I sell them and a set of DA's and springs are STILL not that much.
__________________
I don't know about you guys, but I think that it's incredibly cool that the owner of a well-known company takes the time to personally answer questions and interact with individuals on a forum. Now THAT'S customer service!
Way to go, Sam; I wish that more of our politicians and elected officials were like you!
LS1TECH Sponsor
Thanks Z28RS. I try, and it truly tears me up when I'm blasted for trying to help. Thank you!
Sam
Sam
__________________
#32
Ive personally been on QA1s before and hated them, overly loose and floaty while being jarring at the same time, awful feel and control.
Heres an example from a member on here a while ago who went from QA1s to konis, his car just didn't feel stable, was not balanced and rode terrible, all that changed when he swapped over:
https://ls1tech.com/forums/suspensio...ml#post8344345
Write up from Sam:
https://ls1tech.com/forums/7486192-post6.html
#33
teh PuRpL3z
Yeah, I haven't really been active over here for a really long time, so I haven't seen this debate. Appreciate the fast response.
And you're right, the only thing I have to compare them to is stock... not only that, but I went from a bone stock suspension to one with Eibachs, aftermarket sway bars, LCAs, and panhard bar pretty much overnight.. the suspension was so different I'd have to admit it would be hard to judge what differences came from which parts just on the old butt meter.
Reading all this stuff has me a bit intrigued now... The QA1s been on my car for 8 years now, suppose it's probably getting close to time to replace them anyway..
#34
Well I no longer have the Bilstein shocks/struts. I did just pick up a set of Koni's SA. 8241-1139SP for the front and 8241-1140SP for the rear. We shall see how these work out. I was going to go with middle adjustment on front and full soft on rear? Seems to be the setup everyone is starting out with. I will be getting springs here in the near future, but who makes the best watt's link for our cars?
#35
I have stock control arms and the car puts the power to the ground just fine. It rides well and takes corners very nicely (ie..no snap oversteer). If you need to get new bushings, Strano sells moog bushings (which I have read are the same as the 1LE bushings for our cars).
#36
#38
http://www.stranoparts.com/partdetai...D=67&ModelID=7
#39
Midwest sells their own Watts link cause the Fays2 wont fit their axl tubes. So if you plan on keeping your stock 9 bolt or a 12 bolt a Fays2 will work and is just the best out there...you can read for yourself
#40
Nice, my suspension setup is almost going to be identical to yours! Do you have a watts link? If you do or don't, how does your car handle? My setup is going to consist of 2001 WS6 with Koni SA, Strano springs, Strano front and rear adjustable sway bars, UMI roto LCA, UMI 3 point SFC, Fays2 Watts link, and a MWC driveshaft loop.
