Founders Performance Torque Arm
Old Jul 11, 2013 | 10:03 AM
  #101
Rare96LT1Formula's Avatar
Originally Posted by unioncarpenter84
call summit they will match the price and will give u free shipping
I decided to pass and wait on Founders. They've definitely done right by me in the past, so I feel the least I could do is be patient and wait it out. Looks like a nice piece, and a nice price!
Either way, Made in the USA parts are the way to go.
Old Jul 15, 2013 | 11:58 AM
  #102
Bump for updates!
Old Jul 16, 2013 | 08:51 PM
  #103
JakeFusion's Avatar
Super Hulk Smash
I'm in for this...
Old Jul 17, 2013 | 08:32 AM
  #104
Reject's Avatar
oh wow i'm amazed that i'm just learning about this now
Old Jul 21, 2013 | 09:55 AM
  #105
Stutz's Avatar
I remember reading this in January then completely forgetting about it. Looks like I haven't missed much.
Old Jul 21, 2013 | 06:04 PM
  #106
Blackpanther99's Avatar
Well that was alot of excitement for nothing
Old Jul 24, 2013 | 05:05 AM
  #107
Richard Schmidt's Avatar
Just got a email from them an they said in email. Should beready to ship late next week.
Old Jul 24, 2013 | 09:25 AM
  #108
KWIK84's Avatar
FWIW tunnel mounts will hit the tires hard, great for lower HP cars.
Old Jul 24, 2013 | 02:55 PM
  #109
ThoR294's Avatar
93-02 here... not many turd gens lurk here
Old Aug 1, 2013 | 08:33 PM
  #110
Founders Performance's Avatar
Main body of the torque arm is welded and we are now moving on to welding the axle brackets. The completed torque arms should be going to powder coat no later than Monday. We are hoping to get them up on the website this weekend for Pre-Sales with a price of only $223.82 in adjustable form only.
Old Aug 2, 2013 | 12:24 AM
  #111
JakeFusion's Avatar
Super Hulk Smash
Excellent!!!
Old Aug 2, 2013 | 01:14 AM
  #112
SparkyJJO's Avatar
I forget, is this the long or short arm? I know there was talk both ways earlier, not sure which you guys are producing first.
Old Aug 3, 2013 | 08:23 AM
  #113
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Hate to be a wet blanket, but right now you can get the UMI Adjustable TA for $225.99
https://ls1tech.com/forums/suspensio...-225-99-a.html
Competition is healthy...
Old Aug 3, 2013 | 02:27 PM
  #114
We are adding these to the website as I type. They should be available for pre-orders in about 5-10 minutes with a special (Sorry it took so long price) of $179.06.
Old Aug 3, 2013 | 02:48 PM
  #115
Default Now Taking Pre-Orders For Shipping Starting 8-08-13
Transfer more or your power to the wheels by with this Founders Peformance adjustable torque arm. This unique designed aftermarket torque arm replaces the flimsy stamped stock torque arm adding strength, rigidity and eliminating flex. This super strong tubular torque arm is a direct bolt on replacement using existing mounting holes and requires no drilling or welding. Founders torque arm is designed to eliminate wheel hop under hard acceleration and reduce your 60-foot times. All necessary parts are supplied with this tubular set-up including a low deflection Energy Suspension front bushing which replaces the stock rubber bushing and bolts in with the existing clamshell. The rear torque arm mount is constructed entirely of high strength grade 50 steel (not the more common 1008, 1010, or grade 30) CNC laser cut and is fully pulsed spray welded with extra material around the mounting holes compared to any other torque arm on the market. This set-up features on-car adjustability for easy pinion angle adjustments using forged 4340 Heat treated adjuster and high strength alloy steel solid rod ends. This makes this the strongest adjustable torque arm on the market at the most affordable price! Designed to fit GM 10-Bolt rear-ends, Moser and Strange 12-Bolts as well as most 9" housings.
Build Features:
  • Constructed Of 1.250" x 0.120" DOM Seamless Steel Tubing
  • Pulsed Spray Welded Tube Adaptors With Rosette Welds For Extra Strength And Durability
  • Forged 4340 Chrome-Moly On-Car Adjuster And Heat Treated For Superior Strength Strength
  • CNC Laser Cut Mounting Plates With Properly Sized Mounting Holes (not sloppy holes like other torque arms) For The Best Accuracy and Fit
  • Rear Mounting Plates Made From Grade 50 High Strength Steel Designed To Fit Stock, 12- Bolt, and 9" Rear-End Housings.
  • Rear Mounts feature Solid Alloy Steel ¾" Rod Ends
  • Front Mount Has A Double Tube Design For Extra Strength Up At The Transmission
  • Solid Front Mount Going Through The Transmission (not a single weak) For Solid Strength
  • Added Material Compared To Other Torque Arms On The Axle Mount For Added Strength Around The Bolt Area
  • Center Support For The Torque Arm Captures The Weld Bungs For Added Bung Strength.
  • Durable Powder Coat
Torque Arm Benefits:
  • Designed to eliminate/reduce wheel hop and solves traction problems
  • Stiffer arm reduces front end nose dive during braking
  • Solid construction prevents breakage and reduces down time
  • Allows for pinon angle adjustments on the car
  • Polyurethane bushing eliminates deflection
  • Bolt-on design requires no welding or drilling!
Better Photos Coming Soon!
Old Aug 3, 2013 | 02:49 PM
  #116
Reject's Avatar
will you all have a short arm version or maybe a tranny xmember that removes the TA from the tailshaft housing?
Old Aug 3, 2013 | 02:52 PM
  #117
Now that this one is done we are moving on to the short tunnel mount and then we will move on to working on the relocation kits.
Old Aug 3, 2013 | 02:53 PM
  #118
Reject's Avatar
what i like to hear!
Th400 come stock right?
Old Aug 3, 2013 | 03:10 PM
  #119
SSInnovations's Avatar
Order Placed!! I have been waiting all year for these to be ready, the price is even better than I expected.
Old Aug 3, 2013 | 05:01 PM
  #120
Sail Hatan's Avatar
Laughed out loud, wet blanket got me. Idk why
