Can you use a Traction Control ABS block on a car without TCS? Capping off extra port
So i burned a hole in some of my break lines and the fittings were stripped in the ABS block from a previous time. So i decided to just buy a new ABS block and all new brake lines
Well the ABS block i bought was for traction control , which my car doesnt have, and the TCS has an extra port on the back of the ABS block, which appears to operate each side of the rear brakes instead of one line that splits into two lines at the rear
Can i just cap off one of the holes on the rear of the ABS block and it will work fine? Or will it cause issues and i just need to get a regular ABS block without Traction Control
