turbo k member
Yes, it can be done as long you are working on a lift and have a good way to support the engine/transmission.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
One way to do it is to have a shock tower brace on the car. Use a ratchet strap over the stb around the headers on each side.
I had to swap my oil pan gasket so I lowered my kmember down 5-6 inches to get the oil pan out, and supported the motor this way. I also put a brace under the crank pulley just in case to stabilize it.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
i swapped my Kmember in my garage on my back with my car on jack stands. i just supported the bottom of the oil pan with a few blocks of wood and a jack stand. Thought it would be a pain in the ***, it actually was not that bad. Dropped the stock K by myself, and put the new tubular one up and in my self. Just sucked holding the new kmember on my forearm with one arm, and trying to get the bolts started with my free hand, but got the bolts started in less than 5min.
