Traction
Old Mar 5, 2013 | 01:14 AM
tylerwalton30's Avatar
Default Traction
What can of advice do you guys have for a decently priced suspension for a good ride and traction? I have a bone stock 99z28 and brand new tires but I'm losing control in shifting to second and have to get off it most of the time.
Old Mar 5, 2013 | 09:03 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
We really need some more details before we can help you out. What kind of tires are you running? Is the car equipped with a manual or automatic transmssion?
With a stock car generally a good set of tires or drag radials will make all the difference in the world when it comes to traction. For initial suspension mods for traction most guys start with rear lower control arms (TCA001) and relocation brackets (CAB002).
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Mar 5, 2013 | 09:10 AM
Bump
Need help guys
Old Mar 5, 2013 | 09:13 AM
Oh didnt see this for some reason
It's a A4
Honestly couldnt tell you what type of tires I'm looking to lower it and get a better hook when I go WOT
Old Mar 5, 2013 | 09:26 AM
BMR Sales2's Avatar
It's a A4
Let us know what kind of tires you currently have and that will be a big help. More than likely you have a cheaper tire with a less than desirable traction rating because a stock automatic f-body shouldn't have too much issue hooking up.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Mar 5, 2013 | 12:02 PM
Thanks ill figure that out after work and get back to you guys
But what's a decently priced suspension ? Or as the other guy said lower control arms
Old Mar 5, 2013 | 12:28 PM
Guitar's Avatar
LCAs and subframe connectors are what I would do first.
Old Mar 5, 2013 | 12:33 PM
BMR Sales2's Avatar
Here is what I would do and what will give you the best bang for the buck as far as stright-line performance and traction goes.
Non-adjustable lower control arms (TCA001) - $109.95
Bolt-in relocation brackets (CAB002) - $99.95
__________________
Glenn ***
Sales Tech
813.986.9302
Old Mar 5, 2013 | 11:14 PM
Does non adjustable compromise the ride if I'm turning and so on?
Btw thanks to anyone that has reied to this so far I really appreciate the help
