I want to do some suspension maintenance.
Im tired of the little bumps here and there feeling much bigger than they are. I know i need to replace my shocks and im working on getting a set from a member here. Other than the obvious shocks and springs, what is going to lessen the bumps, jarring and tramlining. Should i just buy a new bushing kit from energy? will that take care of what im talking about? I know i will be purchasing an adhj PHB STB and LCA's. But this wont help with the rattles and squeaks. Just want to tighten it all up again. thanks in adance.
think of agx 8 ways with bmr springs if i can get a deal on them. yea i am thinking the enrgy bushing will make everything stiffer, which is ok i would like it to have a tight feeling...lol. Is any part of our suspension greaseable? I know its never going to ride like a cadillac would, just dont want the loose feeling i have now. I know i am going to have to buy inner and outer tie rods as well. those are pretty shot.
Shocks are for rebound not the initial jolt of a bump or pothole. Do you have very low profile tires?
Seems like you may want conflicting things.... A tight handling car and soft ride... Tough balance.
I'd avoid poly bushings if you don't like bumps as it is. The rubber stock bushings are the best for absorbing all the little impacts and not transferring it into noise or bumps.
Harsh ride can be a balance of two different things. On one hand, your shocks may be too worn and not enough control which increases the speed you hit your full suspension travel. On the other hand, if your shocks or springs are too stiff then your body is absorbing more of the impacts.
ok so im gonna start with this;
Ill get this set of agx 8 ways with the BMR springs, see how that goes. Im hoping my stock bushing have something left in them. ill see how that goes. id like to get it a little lower anyway. I have goodyear f1's, the ride is FINE. Im not lokoing to make it softer. Just not so JARRING. like when i hit a bump it feels like my car is shaking apart
Im going to not go with the bushing set yet. Ill see how the shocks do at helping things out. Since im lowering it with the BMR spring ill endup getting the phb and lcas. This should help me hook on the street too right?
A STB, PHB and LCA wont "tighten things up". They really won't do anything for your issue at all.
What PSI do you run in your tires?
Not true at all.
Thats the shocks compression that deals with the initial "jolt". Shocks can make a DRASTIC change in how bumps/potholes feel, and how they make the car feel (more solid vs falling apart).
Koni SAs on otherwise stock suspension made my car a night and day difference in how solid and "whole" it was. Felt like it was all one solid piece (SFCs did not do this for me BTW), very composed, planted and unflappable.
Stick with STOCK springs, and bilstien shocks IMO. If not try the AGX's on the stock springs.
Also if you want to hook better on the street you need better tires, period. LCA's will only make things more firm or jarring.
JD AMG:
I run 32 psi in my tires. I figured for a true hook on the street i would have to pickup some ET streets at least. I am hoping that i can just replace the shocks and that will help me out a ton! i mean i can hear my rear shocks pop when i hit a bump about a second after. Its hard to explain but it sounds like when the shock is rebounding it gets to the top and the makes a weird noise like its strugling to release all the way. I am assuming this means my shocks are wayyyy blown.
The only reason i was gonna buy the agx and bmr springs is that its local and cheap. 325 for everything with about 11k on the setup. I am not sure how i feel about buying used shocks tho. I have a feeling that replacing my shocks will make a world of difference.
I dont want to to make this into a what shock thread. thanks for all your help.
Don't mean to thread hijack here, but it seems like a related question and something the OP may want. What's the best way to tighten up the steering? Make the car more nimble? I'm thinking replace the tie rods or lower control arms, or maybe just the bushings, not sure, my car feels all over the place.
I'm really up in the air myself. Mine was built with the Bilstein suspension package. Soon I need to replace here, but the dealer wants 400 bucks each for the replacements on the rear! They have AC Delco Special division shocks for around 200 each and AC Delco HD shocks that I can get for around 100 each... I'm so confused!! Has anyone here used the Special Division absorbers and how did they fair?
I paid less than that shipped for all four to my door.
I hope I just misunderstood you, if I haven't, you REALLY need to shop around...
Multiple places you can buy Bilsteins at for around 400 (all 4 shocks). I was in your situation OP after I bought my 01 SS.
I couldn't afford Koni's, so I bought the Bilsteins from Strano. Even with the stock springs, the car rode well, stopped being harsh and floating after hitting a bump.
I have been upgrading my suspension a little at a time. The car feels great in turns and rides well enough that my wife, who has a bad back, can ride in the car with no issues.
Save yourself some cash and install the shocks yourself. It might take you 4-6 hours, but is WELL worth it.
Do you have to get a PHB or LCAS if you get lowering springs on your car?
Anyone know where you can buy a complete set of replacement bushings for all your suspension parts? I'm pretty sure mine are shot, I just want to go with the standard rubber ones.
