Koni, BMR, Brakemotive Install
#43
#46
#47
I can't help but feel that that bottom strut mount is causing some torsion effect, further stiffening the ride. I had to really work to get them to line up to the holes on the lower a-arm. I called BMR and they said that the tab through the strut with rotate, but Idk...
#48
Update
I just installed c6 spyders with Michelin Pilot Super Sports (Appearance thread coming later).
A few notes:
-Tramlining is GONE. I don't feel the car/road pulling me all over the place anymore.
-The ride is super smooth, like glass, on smooth roads while also super quiet.
-Small bumps, mostly seams in the highway are still very harsh to me. I honestly think something is up with my suspension. When I hit a series of bumps, the car bounces all over the road and is not stable at all.
When I got home today, I measured from the ground to the bottom of each fender. Refresher of my setup
-Stock springs
-Koni 4/4's
-Lower perch up front
-heater hose mod out back
-18x9.5 wheels all around
-275/35 tires up front
-285/35 tires out back
Measurements:
Front Left - 27.75"
Front Right - 27"
Rears - 27.5"
Seems kind high eh?
A few notes:
-Stock springs
-Koni 4/4's
Measurements:
Front Left - 27.75"
Front Right - 27"
Rears - 27.5"
Seems kind high eh?
#49
That does seem really high given that you're on the lower perch. I have Stranos on my Bilsteins on my V6 car, which naturally is going to make the front end sit a little higher than on a LS1 car, yet you're sitting at a similar front height as me despite even being on the lower perch.
That doesn't seem right to me at all... Well, one explanation could be tire height, if you got taller tires than stock. What size tires did you get?
My measurements for comparison's sake -
Front left - 27.5"
Front right - 27"
Rear left - 27"
Rear right - 26.5"
Front left - 27.5"
Front right - 27"
Rear left - 27"
Rear right - 26.5"
#52
The tire place put 44lbs of pressure in the tires. I dropped it down to 36, and it feels a little softer, but still pretty jarring on seams and bumps.
(Yes, I'm aware it's not a Cadillac.)
#54
This is actually my next step. It's sort of backwards logic to put lowering springs and expect a better ride, but I've read tons of reviews where folks are happy with the ride on BMR springs. It helps that I have a set on the shelf that came free with the Koni's as well.
#55
I just installed mine this past weekend. Koni 4/3, stock springs, lower perch, stock isolators in the rear. The ride is a little jarring, but I haven't gotten it aligned yet. Also, the tires on it are old and probably hard. It's a little more harsh than my CobaltSS.
But like you said, seams are rough right now.
#56
#57
Bumps and seams don't feel very good when you nail them on a highway. My daily handles those better. I don't think I could put any suspension piece in to make nailing a bump on the highway feel much better in my camaro. My solution is to dodge them.
Do you have stock LCAs or aftermarket?
#58
All stock. My next order of business is the swap in the BMR springs and change out all the stock bushings to new Moog pieces.
When I was swapping my tires I checked out the front lower a-arm bushings and they were cracked and hard like a rock. I couldn't even push a fingernail into them.
#59
As long as you realize you may just not like the feeling in general that this car feels like over rough bumps. I always say my setup feels great. Rides very well over most roads... but not over really rough bumps in the road. I don't really include that category in when I talk ride quality.
Maybe different springs will help it. But it's possible that it won't. It's possible it could make it worse. One thing is for sure, it's going to handle awesome for a street/performance cruiser.
#60
The only thing that changed was the addition of Koni's and my ride quality just seemed to go to ****. I don't remember subconsciously bracing myself for impact when i had the decarbons.
I'm also beginning to get concerns about my y-pipe to ground clearance once I swap in the BMR springs.....it never ends...
