Control Arm Bushings and Ball Joints are IN!!
#41
Here are the front end alignment specs:
Anything off?
Left:
Camber: 0.00
Caster:5.9
Toe: -0.01
Right:
Camber: .3
Caster:5.1
Toe: -0.02
Caster appears to be a bit out of range on the L. And I'm not sure about the toe in.
Anything off?
Left:
Camber: 0.00
Caster:5.9
Toe: -0.01
Right:
Camber: .3
Caster:5.1
Toe: -0.02
#46
There's a bit of a "flange" or "ridge" around the body of the ball joint. You press in the b/j until this flange seats on the body of the a-arm. It sometimes helps if you can put the b/j in a freezer for a couple of hours, to "shrink" it a little before you press it in.
#53
The suspension rubber on my 02 is either cracked or torn so I'm going to replace all of it......
Aren't there a few other bushings in the rear on those horizontal members right behind the diff? Not the sway bar but the ones that form a triangle.
#55
Yes I think so.....can't find the bushing for that though.....maybe its called something else.
Here's the list of what I got including the front strut mounts....cuz mine are thrashed. Please let me know if there is something else that should be on this list.
![](http://content.screencast.com/users/Grednfer/folders/Default/media/192b8a36-fd42-4cee-ba08-61ecd0ff97f4/Suspension%20Bushings.png)
#56
It appears the screenshot you posted shows the front suspension parts, not the rear. You might want to look up the rear suspension section....However, as I type this, I'm thinking that Moog does not sell the PHB bushing separately, as I believe it is molded into the PHB. My suggestion would be an Energy Suspension polyurethane replacement bushing, or a stronger, aftermarket PHB with a poly bushing already installed.
#57
I suppose a PHB with a bushing that allows for deflection would probably be better than straight poly (there is a slight secondary movement on the PHB) but it seems minimal. I got my Founders on-car adjustable PHB for under $100. My stock PHB bushings were really dry and cracked.
#58
I disassembled the front today.....not too bad...about 1.5 hours per side.
I can't believe how degenerated some of the bushings were....all were dry and cracked but some you could see through......and this is a 2002 CA car.
Arms are off to get get prepped and painted....haven't decided what color yet or paint v powdercoat.....concerned about chipping the powdercoat when they press the bushings in......we'll see.
I'll post a PIC when its done.
#59
I got the big ball joint press from autozone as well, where exactly do you press these in? there is only a small lip for the outside of the horizontal bushings, and i can only press the actual rubber, i feel like i am doing something wrong here. Also on the pivot bushing, there is 2 "openings" or "slots" in the bushings, does it matter which way these face? Do they have to face parallel with the control arm, or front to back in relation to the car?
