HELP: Lowering 98-02 F-Body
So I searched around a little but couldn't find anything. I have bought some Eibach pro kit lowering springs for my 2001 SS Camaro and am about to get started on this project. I pulled the car in the shop and started looking around at what all this was going to take. I have a few questions for those of you who have done this:
1. It looks like the brake master cylinder is in the way of getting one of the strut bolts loose and out. What did you guys do to get around this? Take master cylinder loose/out?
2. From looking at and talking to a buddy, it looks like I have to take the front sway bar loose and knock the sprindle loose from the ball joint to get the struts out. Is that correct?
3. To get the rear springs out, do I just need to take the rear shocks loose and drop the rearend down or is there more to it than just that?
4. Are there any other roadblocks/hurdles that I need to know about before starting this project?
Thanks in advance for your help/advice!
-Ben
-Ben
Heres the link http://www.ls1howto.com/?article=6
1. you dont have to remove it, but it helps. You should just be able to loosen it out the way.
2. yes
3. IIRC yes. The rear is really simple but its been around 3 years since i replaced rear shocks.
4. as mentioned in the link, keep something to hold the brake calipers, so they dont hang by the brake lines. Now would also be a good time to replace worn out bushings and mounts. Theres a few threads here where they even show the part numbers for most of this.
2. yes
2. yes
2. yes
Ben
Rear springs, just jack up the car and let the rear hang, use some muscle and you can do it without shocks, but they aren't hard to remove.
otherwise just do what you need for everything. its all pretty straight forward when you go to do it
