Cutting my Shocks shaft to remove mounts. Will this work?
I can't get the bolts off my strut mounts. Is there any way of getting everything apart without removing the nut? I'm trying to add my new springs and shocks. I was thinking of sawing off the shocks shaft.
I am aware of the tension that will be released when it gets loose, so I'll be careful with that.
The nut is probably way softer than the shock shaft, just use a chisel or drill to split the nut in half. It's what I've done and was quick and easy. But please use a spring compressor.
I tried getting the mounts off when i was working one day ended up just getting new mounts and rebuilding the new struts was way worth the $15 per mount i spent.
If you compress them as much as possible, you can just get your blade in there and cut the threaded shaft just below the strut mount. That's how I did mine with a saws all and it took me 30 seconds to cut through it. You can then tap the nut and threaded shaft back and forth and re-use the strut mount. Personally I used new ones since I was already there. No need to cut through the polished shock shaft.
So it's not OK to cut through the polished shaft? If it is and I cut it..will everything just slide off and loosen, how will that work?
Appreciate every ones help.
I can't compress it anymore...I'm to weak. I still have 6" to go befor I max out both compressors...seems like it's good enough.
If it is indeed compressed far enough, then just wedge a saws all blade between the bottom of the strut mount and the plastic piece that sits over the shock.
If that's the case, then you might need to get some help. The reason why I say this is because when I cut the threaded shaft on mine, I still had a slight bit of force from the spring and after I cut through - the top half popped off.
OK, this is where I'm at. FTR, anyone who thinks it's worth a shot cutting the shaft, it's not!
I'll just go for the nut.
