Homemade rear lca's, panhard bar, and torque arm
Anyone made there own rear suspension pieces? The afco catalog has some 1" .095 wall swaged tubes for $15. Get them ordered the right length. The use there 3/4 aircraft grade rod ends. I think they are $25 a piece. I was thinking about a 1" piece of .095 tubing with rod ends for the panhard bar to. Haven't found anyone making there own stuff. use some 1/2 .095 tubing for the torque arm with 1/2 rod ends.
all the time and money put in for all the seperate pieces, you might be better off buying from founders performance. Im not sure exactly what it would take to fabricate suspension pieces or if you have the tools/equipment to pull it off, but i would just buy whats been proven to work instead.
EDIT; or buy used instead.
I do a lot of metal fabri-tinkering.... I enjoy it, and have made some pretty neat stuff and also saved a lot of money, and learned a lot along the way. That being said... A box of stuff from founders showed up today... I can not replicate his parts cheaper than I can buy them...
The strut tower bar took me all of 3 mins to install and 2 of those were spent getting a 15mm socket and ratchet out and putting it away after.
The rest will be installed shortly.
