Brake Mock Up......Is this correct?
I mocked up my brake system at the master cylinder today. My big question is the direction of the residual valve....do I have the arrow headed in the correct direction? I assume it should point in the direction that the brake fluid is traveling to the drum brakes?
Thanks for any advice!
Scott
I'll take a stab at it.
Logic assumes that the arrow points in the direction of flow, as it is a one way valve.
I haven't looked at/in your build thread in a long time so I probably missed it, but what kind of hose/line is that? If it's soft hose, then I'd think about replumbing with some hard line. Seen people have pedal issues with a lot of soft hose in the system. If it's rigid plastic, then you should be good to go. Seen a lot of success with that and have even used it myself on a few projects.
Thank you both for the helpful advice.
