Attention brake specialist!!!! "Sponsors"
Well I did the cts v brake upgrade on my Camaro and I painted the calipers red using VHT caliper paint. I had my car wash guy clean my car and apparently he used wheel acid to clean the rims and the caliper paint is ****. I've got them off, paint stripped and all torn apart seal & piston ready for powder coating. Can I reuse the seals? They have less than 300 miles of normal driving (NO HEAVY BRAKING AT ALL)?
I can't see why not I do this all the time when powdercoating MC calipers for guys with bikes that have just a couple thousand miles on them and at worst the seals are usually just really dirty and need to soak a bit in dish detergent then brake fluid... Are the seals avail seperate in case one is torn? I think you would see it yourself if you took them all apart.
