Strut mount question
Does that mean the strut mount is bad, or the isolator? Shocks are KYB adjustable and are in pretty good condition, not rusted all to hell when we took the assembly out. The top of the strut rod is hitting the body of the car. What stops it from moving up and down inside of the strut mount?
thanks!
I would definitely look at the strut mounts because they are more than likely going to be the issue. I would pull everything apart and make sure the little isolator piece that sits on top of the strut mount is there and if it is I would suspect that you have a bad strut mount.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Why they didn't just build the metal plate into the mount and make it all one piece I'm not really sure.
The other piece you saw in the 1st pic is a rubber seal that goes on the upper a-arm bracket to seal the mount from water.
MOOG K6573 (2)
MOOG K6516 (1)
MOOG K6517 (1)
Rock Auto is definitely the best place to get these parts from.
Glenn ***
Sales Tech
813.986.9302
