Koni STR.T FINALLY available for 93-02 f-bodies?! (well, almost...)
#61
LS1TECH Sponsor
Well, for what it's worth I read the other thread you started. And it occurs to me the best shocks you had were Bilstein's. You had some adjustables, but nothing like a Koni, and you saw that even with some quite soft springs they didn't ride so well, which shows you what a shock can do poorly with soft springs. Stock shocks are "soft" and are pretty harsh, that only gets worse with stiffer springs because they have no hope of good control over them.
As for not needing adjustment. Wellllllll, maybe. If the adjustment is a good one, and useful it's nice to be able to tweak. Trouble is the "adjustable" shocks you had had kind of lousy adjustment mechanisms. All adjust a bypass, not the oil that passes through the piston of the shock. Basically that is what makes the shock do things at different piston speeds and you didn't have it.
__________________
#63
8 sec potential, 12 sec slip
Welp, mine arrived today! That was very fast shipping for sure
thanks strano!
I already have a very jam packed busy weekend, but i HOPE i can squeeze in installing these. Sorry i wont be able to do a comparo vs other aftermarket shocks since i am replacing my stockers with these. I really hope these make a difference for me in ride quality. I have DMS lowering springs btw. I will post back up here after i have had some seat time.
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
#66
#67
Not F-body related, but I install a set of the Koni STR.T on a friends Civic along with H&R sport springs, and he's been very happy with the control the Koni's offer.. IMO, they seem to be a good option other than Bilsteins.
I do see by your photo's ( vSPECTRE ) the koni's are clearly shorter than the stock shocks which will help with the ride quality especially with lowering springs.
#68
#69
With the shock being a little bit shorted it means you have more compression travel before your into the bump-stops and possibly bottom-out the suspension. So you'll have a better ride quality and more controlled handling. At slower speeds on very smooth roads you won't really notice it but at higher speeds over less than perfect roads you'll appreciate it.
#77
LS1TECH Sponsor
Glad you like. Exactly what I was expecting, and what I've found when comparing Bilstein and STR.T's on other cars (Mustang, BMW, and Honda primarily).
__________________
#79
LS1TECH Sponsor
Got a couple fronts, no rears. Nobody can say I didn't warn the group about low stock and getting while the getting was good. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
ETA on more rears... sometime in February, but backorders are already piling up for those, so the longer you wait, the longer you'll be waiting. Fronts after this last set I have is gone are also out, but more are already in transit (but not that many only like 20 car sets total), and will be here before the rears, likely to be 2-3 weeks from now.
__________________
