What to buy to fix alignment issue?
Old Aug 1, 2013 | 06:31 PM
jayfire's Avatar
Default What to buy to fix alignment issue?
I have an 02 WS6. Put new shocks in and lowering springs, took it down to get the alignment and after all the adjustments they said it is out as far as it could go and that it will still pull to the right a little and wear out the inside of the tires faster. What do I need to purchase to get my alignment back into compliance? Thanks
Old Aug 2, 2013 | 05:07 AM
Tbird232ci's Avatar
Do you have the specs? Did they give you a sheet to show you what they couldn't get correct?
Old Aug 2, 2013 | 07:52 AM
camarokid91's Avatar
I second this you need to post numbers.
Sounds like one side has to much toe or camber tho.
Old Aug 2, 2013 | 03:25 PM
LILWS6's Avatar
pull would be either caster or camber but if they didn't provide you with a printout after they aligned it we can't help you. The specs tell everything.
Old Aug 3, 2013 | 12:26 AM
99Bluz28's Avatar
IMO, sounds to me like you need to find a better alignment shop.
Old Aug 3, 2013 | 05:27 AM
high impact's Avatar
This^^^^. Do you know if the car has ever been in a wreck? If so then it may need a little tweaking on a frame machine first. if this isnt the case then your shop is lacking in ability.i have seen many so called alignment techs over the years who didn't know how to perform proper caster sweeps on the rack and have a difficult time setting caster/camber correctly.
Old Aug 3, 2013 | 02:31 PM
99Bluz28's Avatar
Good point, this is the only excusable reason why they can't get it aligned.
Even then a seasoned alignment shop tech would likely notice the signs of a car that's been wrecked, but not fixed correctly.
IMO, if you have any local performance shops that lower cars ask who they have do alignments for them.
Old Aug 4, 2013 | 11:12 PM
jayfire's Avatar
Thanks for the replies. I am the second owner, 69k miles. Did the alignment at a Les Schwab. I will see if I can find the spec sheet I got and post. Thanks
