Founders Performance On Car Adjustable Torque Arm Now Available And On Sale $179.06
Old 08-07-2013, 03:28 PM
ThoR294's Avatar
ooooooooooooooo
Old 08-07-2013, 04:48 PM
Founders Performance's Avatar
Originally Posted by studderin
got any better pics of the front mount, and the piece separate? the sleeve is molded in the bushing? and the TA shaft slides on that dry?
The outer sleeve/shaft is bolted to the torque arm using a 5/8" grade 8 bolt. That shaft OD gets the grease and acts just like any other torque arm. We went this route to make the front mount stronger. Our torque arm has a solid front mount (5/8" grade 8 bolt, outer steel sleeve, then bushing), all other torque arms just use the tubing to support the front load putting a single piece of 1.25"x.120" in most cases in bending. The 5/8" grade 8 bolt calculates to a single shear strength of 27,611.1 min/lbs. which is much stronger than round tubing in single shear.
Old 08-07-2013, 07:57 PM
38DD2436's Avatar
Smart design^^
Old 08-07-2013, 08:20 PM
tony1784's Avatar
Originally Posted by Founders Performance
The short arm will be available before the relocation kits.
when you say short arm, you mean a tunnel mount style TA?
Old 08-08-2013, 06:45 PM
The Scammer Hammer
dr_whigham's Avatar
I started the original Founder's Performance TA thread, and while I'm happy the product has finally been released, it concerns me the TA relocation bracket didn't come out at the same time, and doesn't appear to be on the horizon either.
I know some of you guys beat your cars like I do. I feel I, as well as yourselves, can get away with it a bit more due to the fact of a having a **** rubber bushing and a flexible stock torque arm... The transmission tailshaft isn't getting the full "brunt of force" if you will.
Founder's, I'm glad you guys pushed and got the product released, but a poly TA bushing and stronger torque arm (single shear strength 27,611.1 min/lbs....) sounds like a fine recipe for a busted transmission tailshaft, and quick.
SO, until you guys release the TA relo kit, is this product reciprocal / compatible with any other manufacturers relocation kits?
Old 08-08-2013, 06:50 PM
38DD2436's Avatar
Just ordered one today. Sorry UMI. I like your stuff but this was a great deal and a real nice TA.
Old 08-08-2013, 06:53 PM
38DD2436's Avatar
This will fit UMI's relocation kit. (I asked them) UMI and Founders use the same factory mounting point for the rubber/poly bushing.
Old 08-08-2013, 07:16 PM
Decadence75's Avatar
It's supposed to work with any relocation brackets that also works with a stock TA since it is still using the stock clamshell to hold the bushing. I just ordered the TA and will shelve it for a little bit to see how long it will take them to start putting out the relo bracket. If it takes too long I will probably pickup the UMI one since they are supposed to play well together.
Old 08-09-2013, 02:16 AM
Josh18Fan's Avatar
Ordered one. Can't beat the price.
Old 08-09-2013, 08:39 AM
Ws6Dnero's Avatar
good thing I already picked up a bmr relocation crossmember for $120. Just waiting on torque arm to get here
Old 08-09-2013, 02:20 PM
These will fit all torque arm relocation kits.
The introductory sale price of $179.06 will expire at the end of 08-15-2013 and return to the normal price of $223.82 so now is the time to order to save the extra $$$.
Old 08-09-2013, 04:22 PM
  #32
Ws6Dnero's Avatar
Got confirmation and tracking number on my order. I'll post pics once received.
Old 08-09-2013, 04:28 PM
  #33
love2ride450's Avatar
I received my shipping confirmation as well. I'll be installing the torque arm, Lower control arms, and relocation brackets one at a time so I can feel the difference each part makes. I'm very excited!
Old 08-09-2013, 04:39 PM
  #34
Chaos07's Avatar
Got mine ordered.
Old 08-09-2013, 11:58 PM
  #35
Josh18Fan's Avatar
Also got my shipping confirmation. That was super fast. Too bad I won't be able to see or use it for another several months.
Old 08-10-2013, 06:46 AM
  #36
38DD2436's Avatar
On thew way!
Old 08-11-2013, 11:36 AM
  #37
LetsRide's Avatar
Ordering right now. First piece to my suspension mods. I'm excited to say the least.
Old 08-14-2013, 08:57 AM
  #38
Super Hulk Smash
JakeFusion's Avatar
I'd love to have the Relocation Mount available too...
Guys with true duals can't run the shorter torque arm.
Old 08-14-2013, 10:09 AM
  #39
Ws6Dnero's Avatar
Lol you guy's should've put some instructions in here on putting it together. ill figure it out though
Old 08-14-2013, 12:05 PM
  #40
Ws6Dnero's Avatar
had to tap it in, very tight fit
Good quality torque arm though
Quick Reply: Founders Performance On Car Adjustable Torque Arm Now Available And On Sale $179.06
