Caliper-to-spindle bolts?
Old Sep 20, 2013 | 02:20 PM
MasterTomos's Avatar
Default Caliper-to-spindle bolts?
I purchase spindles and 98-02 calipers for my '95 car separately, of course neither came with the bolts to connect them to each other . Where can I pick up a set of these? I'd prefer new but Rock Auto doesn't have them and I'm not sure where else to look.
Thanks in advance
Old Sep 20, 2013 | 05:26 PM
Decadence75's Avatar
Bolt to connect the bracket to the spindle should be part number 18023646
I believe it is a M12x1.75 35mm if you wanted to get one from a hardware store to test out.
Old Sep 20, 2013 | 08:13 PM
bowtiedad_z28's Avatar
I ordered mine through the local hardware store when i did my swap.
Oh and just make sure you use the hardened ones. 10.5 was there grade on the factory bolts.
Old Sep 20, 2013 | 11:42 PM
Sweet, I believe I've found them on GM parts direct for just a few bucks. Thanks guys.
Old Sep 21, 2013 | 11:57 PM
Alright man, good deal. Good luck with the install!
Old Sep 24, 2013 | 02:29 PM
Sounds like I may have to order through a hardware store or something. GM parts direct switches the 18023646 part # which is package of 5 bolts for $2.51 + $12.95 shipping (an absolute joke) to a new "updated" 18060356 part number, which is a package of 1 for $3.95 each plus shipping. I'm not paying $28+ for 4 bolts. Local dealership wants $5.86/bolt as well.
Of course, Rock Auto doesn't have them, either.
Still need to check with the parts store.
Old Sep 25, 2013 | 05:21 PM
Thats exactly why i ordered them through our hardware store. I was in no big hurry at the time because it was winter at the time.
Old Sep 25, 2013 | 08:24 PM
Would you by chance be able to verify the size/thread of the bolts you ordered?
Old Sep 26, 2013 | 09:47 AM
mab6680's Avatar
M12x1.75 35mm is correct make sure you get shoulder head bolts. if you use your plane jane bolt it will back itself out.
Old Sep 26, 2013 | 01:00 PM
Awesome, thanks. Also, but forgive my ignorance, but "shoulder head" bolts just don't have threads up to the head, correct?
Like these:
http://thumbs1.ebaystatic.com/d/l225...EXRWZXzhfw.jpg
Or is there something more to it?
Why would non-shoulder head bolts back out?
Old Sep 27, 2013 | 07:23 AM
mab6680's Avatar
yes those are the correct style but the "shoulder" part of it is the ring that is right below the hex head. it backs out because it doesnt have the shoulder on it.
Old Sep 27, 2013 | 06:37 PM
Nice catch on the bolts with shoulders. I should have mentioned. And yes that is the correct size.
