stuck on swapping knuckles
Old Sep 26, 2013 | 09:27 AM
vertiroc's Avatar
Default stuck on swapping knuckles
after taking the nuts off and dropping the tie rod end, will the knuckke just come off? or do i need the ball joint separator for top or bottom because its not budging?
Old Sep 26, 2013 | 09:51 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
If you are working on a 4th gen f-body you will need to unbolt the upper and lower ball joints nuts. Once you do this you can generally use a hammer and tap on the spindle close to where it slides over the ball joint studs and it will free it up and allow you to remove the spindle.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Sep 26, 2013 | 10:50 AM
vertiroc's Avatar
Appreciate it. Got em off.
