School me on LCA's Relocation Brackets
LS1Tech Premium Sponsor
And brake worse! The brackets might help straightline traction by forcing the wheels down under acceleration, but they also try and lift them up under deceleration. This creates bad axle hop under hard braking and really srews with the ABS.
It is all a compromise based on what you do with your car. For a lowered DD/handling car, I no longer use the relocation brackets because the handling and braking tradeoffs were worse than the traction benefits.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I see in your signature that you used the Founders Suspension products, I was going to order the LCA and panhard bar package and then the LCA relocation brackets too, what do you think of their product quality because their prices are great!!!!
I have their LCA relocation brackets, double adjustable panhard bar, and STB and must say their quality and product are top notch. The other manufacturers should be embarrassed to charge what they do compared to Founders.
Instead of creating a new thread, I'm going to go off of this.
I keep reading different **** everywhere.
I got a set of bolt on LCA relocation brackets practically for free, so I am toying with the idea of installing them on my car.
99% street car, maybe see the drag strip once every 2 years. From what I am reading, LCA brackets HURT handling/braking, even if my car is lowered? Wouldn't the brackets help fix the LCA geometry since I lowered my car? I don't want to hurt my handling, so I figured the brackets would bring it back where it should be.
My car is lowered and I have welded LCA brackets, I have LCA set on the first set of holes (not the bottom) and I have great performance (spirited driving and drag racing 2 times a year). When I had them in the lower holes I notice some unstable movement in the rear of the car. Doesn't take long to adjust them. This is my personal exp. I am by no means a suspension master.
Adding Anti-Squat will make the car Squat less during acceleration. This will cause your car to track straight on straightaways. It will also make your car push coming out of corners, but loose entering corners.
Less Anti-Squat will result in the opposite: a little less forward traction, more stable entering corners, and will track through bumpy sections much better.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Lowering the rear control arm mounting point will shorten the instant center and add anti squat.
No, If you lower the car you need to restore the geometry to the proper angles with the brackets.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
