Camber question
Alignment shop said they could NOT get my car to stay in spec. Drove it around the block and it was screwed up again.
Passenger side
Driver side
Front-ish
But if they can get it to spec, and then it doesn't stay, something else is wrong. Like trashed bushings and/or ball-joints.
I'll install all the passenger side parts tomorrow and post a picture. Hopefully it straightens up.
(New spindle upper arms shocks springs)
The lower a-arms are moved inward or outward, to adjust camber/caster. The arms are held in place by two bolts, one vertical (caster) and one horizontal (camber). Yes, there is a specific tool called a "J-hook" that some alignment shops, and most Chevy/Pontiac dealers should have. And some serious enthusiasts like me, have two of them. It makes the job a lot easier. However, if you loosen the bolts a LITTLE, and GENTLY pry against the a-arm with a pry bar, you can slide the a-arms around.
BTW, it makes NO DIFFERENCE what diameter your wheels are....
Just want to make sure after doing some research if this one would work on 93-97 cars.
http://www.andysautosport.com/chevro...p00433092.html
If not than ill call the dealer.
