Power Streeing Pump issue
Old Oct 7, 2013 | 01:40 PM
Teapot's Avatar
Default Power Streeing Pump issue
So I changed my power steering pump do to a leak which was soaking my alternator and the new pump is wining like crazy. I bleed the system following the Chilton manual except for lifting the front tires off the ground. I not getting any more air out the system however I guess there is still air in there. What else do I need to do that I apparently did not? Are did I get a bad pump?
Old Oct 9, 2013 | 11:15 AM
brigade24's Avatar
the stock pump is notorious for leaking from the top cover...soaking the alt.
next time go with a turn one ps pump...expensive but quiet.
i bled mine with the wheels off the ground and the noise went away gradually...it took a long time...like 40 cranks each side.
Old Oct 9, 2013 | 12:47 PM
camarokid91's Avatar
My turnone leaks a bit when I am racing but it not that big of a deal. Compared to the stock pump.
Old Oct 9, 2013 | 02:54 PM
79_T/A's Avatar
Do you run a cooler along with the turn one pump? I know you race a lot. I just picked up a pump from them and I'm thinking of adding a cooler also because of the way the car gets driven.
Old Oct 9, 2013 | 03:17 PM
I will be getting one this winter from Alan Blaine but I did not run one this spring/summer. Everything seemed to be fine once the PS fluid leveled out. I think I put 20 events on this pump this summer.
