Ebcm
Old Oct 15, 2013 | 06:26 PM
Dave's02SS's Avatar
Default Ebcm
Having a problem with ABS, Brake and ASR lights popping on in an 02 Camaro SS and had a scan today. Came up with a code indicating the need to replace the Electronic Brake Control Module. Would appreciate any help or suggestions on where I can go to buy one - did a real quick Google search but no good results. Also, for someone not very electronically versed, how complicated is the replacement if I try it myself?
Old Oct 15, 2013 | 07:13 PM
sicksspeed's Avatar
very simple, you need the electronic part, module I would bet same thing happened to my 01 z. find a person/ place selling one from same vintage with 4 wheel abs and traction control. doule check if necessary with a gm dealer on part # unbolt module from side of ebcm and bolt on plug in. Good to go. should confirm tire size programed in module but dought you would notice difference. but before that suggest checking the ground on top of fender that sticks up next to ebcm. good luck.
