Lost ABS, found torn wires. Need help IDing where they go.
Hey gents, like the title states.. After I did my trans swap I lost abs shortly after, initially I thought I had knocked a connector loose somewhere when I was cursing at re-installing my torque arm. Today I was doing some maintenance and poked around, I couldn't find any other wires where these could splice into? Take a look, maybe you guys have an idea. Axle is a Strange 12 bolt, I didn't swap it in so I have no idea where the hook ups are- I only see what I can with the car jacked up. Thanks
![](http://img818.imageshack.us/img818/5833/3bvb.jpg)
![](http://img542.imageshack.us/img542/6903/9sao.jpg)
Since you said your abs was working, check strange's website: http://www.strangeengineering.net/
Under the 12bolt link for fbodies there is a diagram that you can zoom into where you can see the optional abs connection on the pumpkin.
Thank you so much! Yes it is a 3 channel axle, I couldn't for the life of me feel out any connector. I hope I can get to it with the axle in the car and it being jacked off the ground.
Yes the ABS worked fun until I did my trans swap, I was having a really hard time getting the torque arm bolted up cause of the way the car was partially jacked up putting the axle at a poor angle so I definitely had my hands rummaging around the top of the axle trying to drop the bolts in.
Thanks again, I'll give it another shot tomorrow- hopefully I can hook it back up.
Tom
Tom
Not good ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
From what I can see with the axle at max droop, there is something that looks/ feels like a nut on top of the pumpkin/ housing with 1 wire coming out about 3", and just another nub of wire in the nut.
I guess its time to figure out how to partially drop the axle and hope there is enough wiring left there to splice into or connectors that I can replace.
To drop the rear end down some rear (let it droop enough so I can see whats going on and get my hands in there to repair it) all I need to do is unbolt the shocks, or is there something else? Its my first solid axle car and I haven't found a concrete answer with searching ![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
I'm also trying to find a picture(s) of how things are supposed to look up there in case I have to buy a new abs sensor or do more monkeying around, but no success so far![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Tom
Tom
