Adjustable torque arm install questions
Old Jan 5, 2014 | 12:47 PM
z-maro's Avatar
Default Adjustable torque arm install questions
I noticed that there is some slop where the back of the torque arm bolts to the diff housing bracket. I was wondering if this is normal, it seems like this would lead to a clunking sound while hitting bumps. Is this ok, or should I try to fill the gap with a washer to snug things up?
Here are some pictures of what where I'm talking about:
Thanks
Old Jan 5, 2014 | 01:51 PM
Undertow74's Avatar
No that space is there so there can be articulation in the roto joint. It's fine.
Old Jan 5, 2014 | 05:19 PM
z-maro's Avatar
Ok thanks, I just thought it seemed a little too sloppy.
Old Jan 8, 2014 | 08:53 PM
z-maro's Avatar
Does anyone know the torque specs for the two long bolts in the rear that connect the bracket to the rear end housing?
Old Jan 8, 2014 | 11:31 PM
LilJayV10's Avatar
97 ft lbs.
If you are using the stock bolts w/ the aftermarket arm remove the washers from the top and use red loctite on the nuts. The bolts aren't long enough to use with the washers on the top. Without them the nuts will be flush with the end of the bolt.
Old Jan 9, 2014 | 01:50 AM
Burken01's Avatar
97 ft lbs.
Good idea
Old Jan 9, 2014 | 03:03 PM
z-maro's Avatar
97 ft lbs.
Do you just go without washers, or get thinner ones?
