2002 ws6 springs
I am looking for stock replacement springs "factory 1" lower". I found these, anyone every ever use it or have a part number for the stock replacement ws6/firehawk springs? I have struts and shocks already.
http://www.ebay.com/itm/SLP-720782798-Spring-1996-00-Camaro-SS-Firehawk-Comp-T-A-Front-Level-II-Replacem-/310407370606?pt=Other_Vehicle_Parts&hash=item4845b8976e&vxp=mtr
SLP 720782798 Spring 1996 00 Camaro SS Firehawk Comp T A Front Level II Replacem | eBay
Also you say you have the shocks already (these cars don't have struts), and by that I hope you don't mean you actually bought the orange/black decarbon shocks, as that would be a huge waste of money, those might as well be paper weights.
I have bilstein front strut "at least when you order then it says struts" and rear shocks and eibach sportline springs now but when i installed my rear mount turbo kit and iron block 5.3 the car is about 1 1/2" from the ground in many areas. The stock springs I took out have 160k on them. I'd like to use fresh ones if I am going through the hassle of doing the work and getting an alignment again.
If you want a replacement spring at stock height, MOOG makes some.
If you want the factory option SLP springs that are a little lower you can get them here: http://www.stranoparts.com/partdetai...=113&ModelID=7
