Brakes, Rotors, and Shocks on a Budget
#41
If you like the bling, I think you should use drilled rotors. Use whatever makes you happy. Dimples are a good compromise here. They have the look of drilled rotors, but are not as prone to cracks. Street cars are just not driven hard enough for the shortcomings to show up.
But if you're building a high performance braking system that is actually used to the max - as in road racing - there's no place for drilled rotors. Max braking lap after lap will cause them to fail. You'll be replacing them 2-3 times a season.
#42
My GP has factory drilled rotors and, while I like the look, they have a low but noticeable buzzing hum which I find annoying. I'm torn on whether or not to go with blanks. The TA? not even a choice. Drilled rotors are more expensive and they crack. It had a pair when I first got the Wilwoods on the front. They lasted exactly one weekend and were trashed. The blanks I replaced them with have lasted three weekends so far, and I'll get three more with new pads and a light cut.
#43
So I ordered my Hawks HPS Pads, and I currently have it narrowed down on rotors.
1. Centric High Carbon Plain 125 (with black hat)
2. All Black Zinc Coated RPM Speed (only come drilled, slotted, or dimpled)
3. R1 Concepts Eline Series (not black)
4. Brakemotive (not black either)
I would really like the all black RPM rotors but I cannot get them blank. I want black rotors becasue of the look honestly. If anyone has had experience with any (except brakemotive I know those are good) I would like to hear about them. Thanks
