snapped caliper bolt!
Old Jun 29, 2014 | 01:54 PM
LilJayV10's Avatar
Originally Posted by RedHotG8
Dielectric grease is for electrical connections not mechanical parts. You want to use silicone based grease so it doesn't get washed away.
Depending the grade of electric grease the OP has it will be fine. Motorcraft sells two different ones. The thicker of the two is also intended for brake slide pins.
Old Jun 30, 2014 | 01:00 PM
chrysler kid's Avatar
That dialetric grease dries out very quickly. Its almost crusty powder substance
You need to re do the pins and re grease them
