Correct end links for a lowered trans am??
I have a 1998 trans am that is lowered on eibach pro kit springs with front bilsteins. I need to change the end links on my swaybar but am unsure what length to use or how to measure it. I am aware that a lowered car requires shorter end links to keep them at a 90 degree angle with the bar and function properly. Anybody know the length they used on a similar setup or have advice to offer? Thanks
If you go to the Energy Suspension catalog and/or website, they have a chart of all their endlinks, showing the various lengths. As the OP mentioned, the key is to keep the swaybar as close to parallel to the ground, so if you can, slide under the car, get the bar where it needs to be, and measure the distance between the lower a-arm, where the link passes through, and the end of the bar.
(Don't go to the "car specific" part of ES's catalog. Check the "universal" endlinks.)
LS1Tech Premium Sponsor
You can use stock length end links. Bar angle in relation to the ground is irrelevant, unless the bar is hitting something from the ends swinging up (which usually only happens if lowered 2" or more). As long as the end links are equal lengths to each other that's all that matters, to ensure there is no preload on one side of the bar.
Most Auto zones and Advance stores stock them. That's where I got mine when I couldn't get an answer from a sponsor for days on here. And I even changed out the front and rear sway bar years ago and they matched up to what I had.
LS1TECH Sponsor
You simply measure the length of the tube and buy the closest one. If you want them shorter for a lowered car, then just order a shorter one, but I agree that's not necessary just one of those things you hear on the web that you have to do.
I have aftermarket links, and I know what to use if you can't find them. Locally would likely be cheapest just because of shipping costs, but not everyone can find them locally.
__________________
When I lowered my car, my rear end links actually had the ends of the bar lower than the bottom of the shocks. While it didn't impact performance, I didn't like that idea. I ended up using slightly shorter spacers (like 3/4") and that brought the ends up a little higher.
In the front there's really no need to go with shorter end-links, but in the rear with lowered and having a aftermarket rear sway-bars and/or if you have a aftermarket 12 bolt or 9" rear end or even a thick differential cover on the factory 10bolt rear end assembly you might need shorter end links to keep the sway bar from hitting the rear end assembly.
