Going back to stock rear lca's & removing SFC's thoughts
Pontiacerator
I noticed the added stiffness going over my first speed bump at an angle post install. But this was also with the stock junk decarbon's. Now that I have the SLP Bilsteins on stock springs, I should have a much smoother ride
I'm thinking the cons out way the pros so far. I have a dimple in my passenger quarter that appeared post SFC install..explain that. Isn't installing SFC's supposed to prevent that from happening? I've never run drag radials or been to the strip with this car either.
I made a thread about it not long ago, some good info in it.
https://ls1tech.com/forums/suspensio...-sfcs-out.html
FYI, your tires have more effect on how your car rides than a set of SFC do.
Keep in mind that the tires you use, the amount of air pressure in them, and bigger/heavier wheels will effect your ride quality. I would recommend swapping wheels/tire with a friend with a F-body for about a hour if possible, that could help you find out if your rolling stock is part of the issue. I would still get those LCAs with the poly bushing off the car. There bad enough in warmer weather, but a lot worse in cold weather.
[QUOTE=RevGTO;18144573]That was one of the reasons I pulled mine and went to stock w/Moog. One of my fittings wouldn't take grease, so I was sure that was the source of my squeak. Turned out I was wrong about the squeak. The poly bushings were not deformed as I had expected, either. I still get dimples after my SFC install. I just get them PDR'd out every couple of years. What I did not get again was the 9" crease in the right quarter from dead hooking without them.[/QUOTE
Well that's good food for thought. I don't recall hating the ride quality so much with the SFCS. It seems that it went downhill after doing the poly/poly lca's. Honestly , my car is a daily driver and a little dent isn't a big deal to me.
Thanks, I saw your thread earlier. An update: I took the poly/poly rear lca's out and swapped in the stock lca's with rubber bushings. Tough to say how much better the ride is now as the roads are below freezing. Plus I had a trunk full of tools banging around on the ride home! But, initial thoughts are that I'm not longer feeling my rear suspension stiffening up over bumps as harshly. I'm cautiously optimistic
Rather than bump your thread I will post in this one. I saw someone said SFC will prevent 1/4 wrinkles...that's not true. Mine wrinkled with SFC. I won't get rid of them though. My car was night and day different. I wish it was tighter because even with all the suspension mods on it my mom's 350z or my sister's miata still smokes it in the turns.
Plus, they are great jacking points.
I put a set of Founders poly/swivel joint control arms on my car a while back. Honestly, there was no decrease in ride quality. I did the control arms, poly/rod end PHB, Konis and BMR's on a 200K mile car and the Konis not being adjusted right made the ride worse than the control arms and PHB.
http://www.foundersperformance.com/p...mbination.html
Those were the ones I used, and they were worth it.
Pontiacerator
I will emphasize again what a difference warm weather and tires make. I was getting really frustrated with my ride this winter; yesterday it was in the 80's and it rode great. Soft sidewall (and plenty of it - 245/50 & 255/50) makes a big difference compared to "rubber band" 35 series tires. They're not much for handling, but it's 95% straight lines in Wichita KS - I'd guess Calgary is the same.
#32
#33
Anyone have any tips for torquing the rear lca's? I have a 1/2 torque wrench but the clearances really suck on the nut side of the lca bolts. I'm thinking I'll pick up a shallow 1/2 19 mm socket with a 3 inch extension but I'm not sure if that will work. I ended up having to use a 3/4 ratchet with a 19 mm wrench on the nut side. Hardly ideal as I'm sure that I didn't get them close to the suggested 90-100 ft lbs as recommended by UMI with the lca's sandwiched between the UMI 2 point bolt in SFC's.
My suspension feels a little smoother, but I'm still getting a very loud bang/clunk from the rear end when I hit a bump in the road or go over a speed bump no matter how slowly I creep over it. I have 6 month old SLP Bilstein's on stock springs. I've tightened the rear shock top hats, bump stops look like they are in good shape, I've checked my end links, pan hard bar, torque arm. I think it has to be insufficient torque on these lca bolts, particularly the rear bolts that connect to the SFC's.
Thanks for any advice!
#34
What bolts are you using? OEM or aftermarket ones provided by UMI/etc? Reason why I ask is I could torque the OEM bolt to the ~80 ft lbs. The aftermarket bolts started stripping the threads well before 80 ft lbs. I had to do about 50-60 ft lbs. 90-100 ft lbs seems way too much in my opinion.
Anyone else want to chime in?
#35
I'm using the stock bolts.
I read a thread here earlier where UMI stated that if you are running SFCs with the lcas you have to bump up the torque to 90-100 ft lbs due to the extra metal tabs that the lca bolts need to go through.
I really would like to know what extension or socket type etc you guys had to use in order to use a torque wrench rather than a regular rachet due to the tight clearances on the nut side of the bolt.
#36
Yes, OEM LCAs & Moog 1LE bushings... I would never want poly LCAs, my fbodies are for DD too! SFCs really did not add much harshness, IMHO.
Stiffer - YES, which was the point of adding them, and they especially help the car track better in turns in convertibles! I also noticed better hooking.
I'd put the stock LCAs back on maybe clean them up and give them a fresh coat of paint and new bushings if needed. IMO, regular poly bushings SUCK when used on the lca's, when used for anything more than driving in a straight line over a perfectly smooth road. They just don't allow the lca's to twist(left or right) enough to avoid a bind free movement. I also really doubt that the SFC
are part of the issue.
I instantly noticed how much stiffer my car was when I did my SFCs... Just pulling out of my driveway which is a slight slope. That was when I had the drag racers mentality. Going for handling and comfort in my car now. The SFCs are coming out before the cars back on the road. Literally the only reason I would like to keep them is the ease of jacking the car up lol.
Poly in both the front and back of the LCA definitely causes bind.... The rear LCA doesn't just move up and down lol. When the body is rolling in a turn, the poly bushing is binding. And yes, anything other then stock with the rear LCAs will cause a more harsh ride.
Like you said you don't drag your car so the answer is obvious.... Put some new moog rear LCA bushings in
#37
I will emphasize how stunned I was at the increase in harshness after the SFC's. It was like every pebble on road was faithfully transmitted into the cabin. Installing Bilsteins helped, but the harshness is still there. The SFC's did prevent a recurrence of creasing in my right q-panel from launching, which is why I had them installed.
#39
I've had UMI lca's, phr, and stb on my 98 T/A for about a year and a half now and love the handling difference. As far asthe ride, it could be a little easier . But I also have a beater vehicle (92 Silverado) that I consider more of a daily. I also came to terms with the fact, shortly after buying my car, that its a sports car and not a Buick regal with wood grain. I just put sfc's on tonight and will get to test them out tomorrow so I can't comment on them yet.
