Eliminate Abs
Old Apr 17, 2014 | 09:20 PM
gak68's Avatar
Default Eliminate Abs
So I saved a 98 camaro 6 speed from the scrapyard. It runs like a top but it's a little rough around the edges (needs some interior work, and exhaust), but the worst is the brakes. All the brakes lines are rusted out including the small braided lines that run from the abs module. I could care less about ABS, so I was thinking about deleting the whole system and just putting in some adjustable proportioning valves and disconnecting the lights in that dash for the ABS TCS. Can I do this without disrupting the rest of the operation of the car?
One final question what outlet on the master cylinder feeds the front brakes?
Thanks in advance for the help.
Old Apr 17, 2014 | 10:28 PM
Daniel Richards's Avatar
5 posts below yours on the page https://ls1tech.com/forums/suspensio...bs-delete.html
should cover your questions.
