Another alignment failure – what to do
I just replaced my shock and spring with Koni sports and BMR 1.5 lower springs. Before I did this, I noticed that my right front tire was rubbing the wheel well a little. Therefore, I assume I needed a wheel alignment. Reading all the post about the challenges with aligning F-body I was not optimistic, but I gave it a shot. Not surprisingly, they told me that they could not get it within specification because of the lower springs. Even though the car was not lower by the springs. It was still at the stock height. The measurements before was Camber -0.6,-0.4, Caster +6.5, +6.2, toe -.65, -.55 and after Camber -0.6, -0.4, Caster +6.5,+6.2, toe 0,0, and the right wheel still rubs. My question is can I live with these specs as I do not know of a good shop that can actual align F-bodies.
Thanks for your response. I was hoping some more members would weigh in on whether my alignment is ok, or whether I should try and improve on it. I read that a number of members with “stock wheel size” have a similar problem with the front passenger wheel rubbing when turning, but I did not see any solutions. Some individuals suggest the bushing may be worn, which is possible with a 113000 miles on my car. Unfortunately, replacing the bushings on the control arm looks like a nightmare. So it is unlikely I am going to do it at this time.
what size tires are you running? take a picture with the wheel straight, I'd like to see if the wheel sits centered in the wheel well to begin with. It could have something to do with the 6 degrees of caster. Judging by your caster and camber settings they did the old Toe n' Go alignment, so I wouldn't have expected that to change anything
The driver side wheels is in the center, but the passenger side is about 1/2 inch forward. This is with stock wheels. I guess that is why it hits the bumper. I do not know why it is and I was hoping the aligniment would help the problems, but they could not change the relationship between the castor/camber, so I am stuck with it. However even if I could fix the camber I do not think it would solve my wheel rubbing. The car has no record of being in an accident and there is no evidence that it has been hit.
If you have one tire sitting half an inch forward and the other straight, that could be why the alignment equipment couldn't get a balance to tell the technician. Have a shop replace your lower A-arm bushings, and if you can get urethane ones, get them. they will last a lot longer then stock. It will be worth it to stop chewing through your front bumper cover and that annoying rubbing.
Did the alignment shop inspect the ENTIRE front end? Did they give you an analysis report? Tie rod ends, ball joints, control arm bushings, upper strut bushing condition... Anything like that at all?
If they didn't, jack up your front end by the center under the engine just enough to get the tires airborn, when they are, grab the passenger tire and try to shove it backwards. also take pictures with a good camera with a flash of the A-arm where it connects to the subframe. Then post those up... I bet we can see what the problem is..
LS1Tech Premium Sponsor
You definitely have some issue with a damaged or bent suspension component. Even on lowered cars, you should not have rubbing issues with the tire to the inner fender/bumper. What bothers me even more is that the alignment shop did not catch nor attempt to correct this. Inspect your lower control arms and bushings because 1/2" difference in wheel center is a big issue. Once you find the cause of that issue, find another alignment shop. Them telling you they cannot change relation between camber and caster on a 4th gen instantly loses credibility with me. The rear lower control arms mounts are setup to allow caster changes with minimal effects on camber. We have plenty of people running our springs with adjustability in their suspension left to set the alignment where you want it. The specs you posted are not terrible, but considering the fact that the wheels are not equally centered (meaning your wheelbase is actually different from one side of the car to the other), I have some concerns about it.
