Help with PHB and LCA's
Old May 3, 2014 | 10:09 PM
1WKDMRM's Avatar
Default Help with PHB and LCA's
I just installed BMR non-adj LCA's and PHB both have poly bushings. After install I noticed the Rear end sitting about a half inch to the drivers side and pushed to the rear of the car about the same. How would I go about fixing the problem besides buying adj LCA's and PHB?
Thanks
Old May 4, 2014 | 02:40 PM
tigearl12's Avatar
Did u measure before the change? And now its different? Just did same thing to my ws6 today and it lined up perfect . Just tested and it hooked better and stayed strsight with 430rwhp and drag radials loved it.
Old May 5, 2014 | 09:34 AM
Jr.Samples's Avatar
I installed the same non adjustable BMRs on mine but did not notice anything "off". I have not drove it either.
Old May 5, 2014 | 04:41 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Thanks
Is your vehicle lowered or factory ride height? The PHB you received should be the same length as the factory one so you can check that and verify the PHB you received is the correct length.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
