Anyone tried these rotors?
Im been lookin for some rotors. and come across these ones.But not sure. How are these rotors compared to our sponsors they seem to be good deal.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
From their advertising: "All rotors are cross-drilled and slotted for high performance that will increase your stopping ability."
Thats baloney. Drilled rotors are really just an appearance item, unless they are cast that way and came off a Porsche... I believer slotting has some arguable benefit depending on the conditions that they are intended to improve.
Your better off with stock replacements over that stuff IMO.
Some guys here go ballistic over manufacturer claims that drilled rotors increase stopping performance. Do some searching around here and I'm sure you can find one of those threads.
OOooo just read the link... 90 replacement warranty for cracks and warping... hmmmm... sounds like they're expecting something to happen??? lol
Originally Posted by txhorns281
True on stopping ability, shouldn't make a huge difference. However, I'm pretty sure the heat disapation properties of aftermarket rotors allow for more consistency and less warping. My stockers would get all mushy once I'd done a few hard stops on em... I did EBC's all around not just for the look, but the actually give me solid braking whenever and wherever... Just my opinion...
There is more info on the technical pages on my website (in my sig).
Have fun!
2. We just try to seperate fact from fiction and help you guys keep your hard earned money while buying safer products (it is much harder to crack a "blank rotor" than a drilled or slotted.)
As a side note, if the slot runs clear off the side of the rotor, a stress riser can develop and they can be very easy to crack along the slots. On a properly slotted rotor, the slot will not "exit the rotor surface". Even then, I'd pass on them, but a slot that is cut in the face and does not run off the outside edge of the rotor tells me the company has a "clue" about what they are doing.
Originally Posted by 9833211
Thanks all for your replys. i would like to see a cracked drilled rotor.Have any of yall actually done this B4?
That is not my rotor. I've always managed to avoid cracking "blank" rotors. This was on a track car and well used. However, I believe Mitchntx had one come apart on him (a drilled rotor that "shattered" as I remember).
I just dropped Mitch a line to see if he had pics.
These are $225 each Porsche 996TT rotors.
13.5" in diameter and 1.375" in width.
I hate them ... but it's the only rotor available for this kit.
But, it's what happens when you buy something before doing your homework.
