rear spring rate
I changed my back to coil overs on my 4th gen, tried the 100# spring and the 125# spring and it still sits really low. I'm about to try the 150# but I don't want it to be rock hard as I DD this thing a lot.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Since you said you have coilovers have you tried adjusting the height? Are the springs you are buying the correct length? There is more to ride height than just spring rate, stock springs are a soft ~114lbs/in but have a really high ride height for example.
The 125s should be a decent spring rate on the car with coilovers.
Adjustment for ride hight is maxed out, he's sending me the 150lb, 14" to install. Should have them Monday.
Right now I have about 1.5" height from wheel to fender lip on drivers side, but only ~1" on the passenger side (passenger side has always sagged for some reason).
Glenn ***
Sales Tech
813.986.9302
