Assembling Koni Front Strut
1) The Koni struts came with four washers, nuts, and bump stops. Why so many? And where does the nut fit? It doesn't actually fit the strut. See attached picture. Also, I assume the washer goes there, but it doesn't seem to fit the Moog strut mount quite flush.
2) Why does the Moog strut mounts and isolators both come with nuts and bolts? I had assumed the Moog strut mounts came with two bolts and nuts for attaching to the car. But the nut actually fits the Koni strut. It's not to be used there is it? Wtf?
3) Where does the isolator go? Is that part of the a-arm assembly or coilover assembly? I don't see a place that looks right for it on this assembly.
4) Does the isolator go where I have it? Also, the Moog strut mount looks like it would fit in the spring, but it doesn't really. Is that ok or do I need to adjust somehow?
5) The lower spring pad from Moog comes with both the pad and the "cup" which is already installed on the Koni - I don't need that for anything, correct?
I realize I will need to compress the spring to get the nut on, but it looks like the way I have this set up, that I will end up compressing the shock as well. And the strut mount will be touching the isolator. That doesn't seem correct to me?
I couldn't find any assembled pictures on how this fits together. And I haven't removed the stock ones yet to see how they fit together.
Any help would be great. Thanks!
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Lower spring perch in place, spring, huge flat washer, upper strut mount, strut isolator, washer, and nylon lock nut:
And Kyle, I didn't have the shocks in the house when I called, but is there a reason they gave me four of the washers, nuts, and spacers? I just use one set per shock correct? I put a washer both below and on top of the rubber bump stop - does it matter which goes where (I assume only use one)? Sorry!
Here is the orientation of everything with it installed from top to bottom on the shock shaft:
Poly lock nut
Cupped washer
Rubber bushing
Car chassis
Rubber bushings
Cupped washer
Glenn ***
Sales Tech
813.986.9302
That upper mount does not fit that spring very well, over time it will conform to the spring and possibly loosen that nut on the top.
I would run it 6 mos and check that nut again.
Or you could get this. I did not install these, they were on the car when I bought it.
EDIT
Put grease all over that top nut and threads, the upper arms hold water. See the rust in that pic?
The upper mount actually fits once you compress the spring and fully torque the nut. I could see that being a problem if you use the nut to torque the mount down. It'll never be tight enough.
