What's the deal with rear caliper bolts?
Old May 19, 2014 | 09:56 AM
Midnight02's Avatar
Default What's the deal with rear caliper bolts?
I've fought with these before and was able to get mine off once I stepped up to a 1/2" drive ratchet, however I have one that now refuses to budge even with the 1/2" ratchet.
I think an air impact would be a quick solution but I don't have easy access to one so I'm going to let some PB Blaster soak before I try it again, however what I don't understand is why they're so difficult to get off? Are you guys using a breaker bar on it?
Isn't the torque spec on the caliper guide pin bolt only 23 ft/lbs?
I could understand if it was the caliper mouting bracket bolt (torqued to 74 ft/lb).
Old May 19, 2014 | 10:17 AM
libertyforall1776's Avatar
All you need is a good mallet to whack the wrench a couple times or a breaker bar works, but I would advise using the fewer number of sides socket so you grip the bolt exactly.
Old May 19, 2014 | 10:40 AM
Midnight02's Avatar
Any chance you recall what size socket it is? I'm away from my car and it would probably just make sense to pick up a good socket while I'm out.
Old May 19, 2014 | 11:12 AM
^ No, but you need one of these: http://toolmonger.com/2009/12/08/cos...scent-toolkit/
Old May 19, 2014 | 12:14 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
couple rear assemblies in garage have 15mm hex. I 'impact' them loose with a good fitting long box wrench struck by a heavy hammer/mallet.
Old May 20, 2014 | 12:35 PM
SparkyJJO's Avatar
I noticed they like to get stuck. But better that than loosening themselves instead.
I have a breaker bar or a long-handled ratchet I use for stubborn stuff like that.
