UMI Torque Arm install Q's
Got the adjustable torque arm w/ relocation bracket and not sure how the pivot links orientate or which holes to use... I attached a pic. Also with the nuts from the pivot links facing the driveshaft, one almost touches it. I have a tips 3 1/2" driveshaft.
The brackets are upside down in the picture. Holes 2 and 3 are for the torque arm and allow adjustment. Flip them over and try the highest hole first.
And yes the bolts get close, especially on larger drive shafts. Where the crossmember mounts to the car it is slotted, you might be able to move the entire crossmember over to get more clearance. You could also flip the bolts the other way or shorten the bolt some.
Hope that helps,
Hope that helps,
