Do I need to compress springs to assemble front struts
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Just ordered Koni Str.t's and Strano lowering springs, replacing my stock springs and AGX shocks. I'm also buying moog strut mounts. I have no intention of dissembling the old struts. Will I need to compress the springs to assemble and install the new front struts?
Super Hulk Smash
I compressed mine. Made threading the nut on top much easier and allowed for an accurate torque reading. I have the BMR springs and Koni Yellows for reference.
It took about 15 mins for the pair. I sat on the couch and watched TV while I did it. I went to AutoZone, rented the spring compressor and within the hour I was back getting my $$ back.
your likely going to need to compress it, I have no experience with the strano's but my BMR/Bilstein combo definitely required it and even if you can get the top nut started you need the spring compressed far enough for fully tighten down the top mount without the spring pushing on it at all or you will likely end up with a "clunking" sound coming from your front end.
compressing the spring instead of using an air gun to hammer down the top nut will ensure the upper mount is seated flat so no banging or clunking sounds. Also, the threads on the shock and the nut are subjected to enormous stress that is not necessary.
Really, compressing the spring down only adds 20 minutes to your whole project... Dont for get to coat the top nut with marine grease or anti seize or whatever to prevent rust at the top nut and shock esp for a daily driver, snowbelt car...
I just ordered Koni Str.t's just for the front (still have stock decarbons) and have the same KYB Gas-a-just's for the rear (about 1,500 miles on my rear shocks.) I was wondering how have the Gas-a-just's held up and how much better are the Str.t's for the rear, when you get the chance that is. I personally, have liked the KYB's for the rear pretty well but am thinking of getting Str.t's for the rear for better handling, but would like some feedback first. Also have one more question: what is the torque specs for the top nut that holds the front strut assembly together? Unfortunately, I will be disassembling my springs and reusing them.
Moderator
Received 1,838 Likes
I used the spring compressors and they worked well - had to compress maybe an inch. Still a pain to snug down the top shock nut as it's got the rubber insert to prevent loosening, I guess. Problem is that it tightening the nut causes the shock shaft to rotate, so you have to hold the top part of the shock in place to tighten the nut, and there is little room to get a wrench in there; but I accomplished it.
Regarding the KYB's, I've found the ride to be a bit clunky (what does that mean? - well I didn't like the way it rode over bumps - kind of jarring I guess), so I wanted to try something different. None of the KYB's had any evidence of leaking and still seem to work OK, with probably 7 years on the car. I have another thread here about some of my experience (aka problems) with the removal and installation process labeled "Do I need to detach balljoints...." in this same forum, for more info. on how the install is progressing.
