Just Gotta Ask.....
That said, Im rebuilding my front end and on a tight budget... so I purchased a set of 16k mile De Carbons from a member here on the site for the freshening.
About 2 years back I bought a pair of unused NOS DeCarbons for the rears. Combined with new LCA's and panhard bar, the improvement was excellent.
So,why does everyone HATE De Carbons?
You won't believe the difference.
I had Monroe Sensa-tracs for the rear of my car when I bought it...and I can say that those were so bad that they were dangerous. From those to decarbons, decarbons retain their valving much, much better and longer.
FWIW, I installed a set of Eibach Pro-Kit springs on my '96 Z/28 back when the car was a couple of months old (I'm the original owner). My reasoning for not changing the shocks, was that A) GM claimed they spent a ton of time and money engineering the DeCarbons for the car; and B) The shocks had all of 5-600 miles on them, when I did the spring swap. I thought the ride was OK. HOWEVER.......
A few years later, I pulled the DeCarbons, and threw in a set of the "SLP Bilsteins". And yes, the difference in ride quality was indeed, "night and day". A couple of years ago, just for grins, I installed a set of the Strano springs and Koni shocks. They handle the bumps well, and ride very nicely, with a good balance of ride and handling.
Koni:
https://ls1tech.com/forums/suspensio...-sa-4-4-a.html
(my review years ago in this thread) https://ls1tech.com/forums/suspensio...-all-hype.html
Bilstien:
https://ls1tech.com/forums/suspensio...ther-mods.html
https://ls1tech.com/forums/suspensio...hd-review.html
The Koni SA's truly are like driving a different car, they not only change the ride and feel, but they change the balance and how the car handles and make the car 1000x more solid.
Rock Auto- $320. shipped
All Moog parts
All bushings for LCA & UCA
upper & lower ball joints
outer tie rod ends
also added the Moog problem solvers for the vertical bushings
Used 16k mile DeCarbons $100. shipped
Local Shop for pressing out/in bushings and lower ball joints $140.
see how easy that was....
I understand what youre saying about the feel of the car... I have had 7 Corvettes and a couple of 2002 Z06's and I know what that connected with the road feel is like. On the other hand, I never had the "floaty" feeling in this Z28. Its always felt solid and really squeak/noise free.... I decided to do the overhaul mainly because of the miles being 150k and then reading about the vertical LCA bushings failing...which mine were torn. Also found the outer tie rod ends pretty loose...just decided to do everything all at once.
let me give you an analogy or metaphor or whatever you wanna call it.
I got a friend who smokes a crapload of cigars and his gf at the time kept complaining that he stunk BIG TIME.
My friend never smelled what she smelled, do you know why?
Because he was USED TO THE SMELL.
picture an f-body owner who always had decarbon shocks, as far as they're concerned, the ride is great...why?
because they're used to it.
doesn't mean that it's a better ride.
there's also the issue of human beings convincing themselves that what they got is the BEST the world has to offer...why? Because they have to justify their decision.
I've had two 4th-gens, first one was a 93Z28 with a 6-speed, I was convinced by many members on another Camaro board circa 1995-1998 that the decarbons were crap and the best setup to buy was Bilsteins and Eibach Pro kits and 35mm front/25mm rear swaybars.
HORRIBLE mistake.
I'm not bragging but I'm a VERY aggressive driver and bottomline my 93Z28 was damn scary to take into the twisties, huge understeer ans the car would fishtail out of the corners and bottom out and the ride was ROUGH!
Rough as in bouncy, stiff, no solid feel, it was a scary car to drive.
I listened to other folks on that site and told me for the money that I should get the KYB adjustables so I did...
same story, still rough ride, understeer, fishtailing out of turns, scary!!!
in 2003 I got my '01 SS 6-spd, I went straight to Sam Strano, he gave me GREAT advice, and I mean great coming from a now 6 or 7 time SCCA autocross champion who makes his own springs and swaybars based on what he learned from the track, so I immediately went with the Koni dual adjustables front and rear, hollow 35mm fronts/22 mm rear swaybars, 600lb front springs via GC Coilovers(not sams choice but I choise to get the GC kit, Sam told me the 600lb fronts would work), and 150lb rears.
Per Sam I adjusted the shocks @4 sweeps from full stiff and rears 3/4 turn from full soft.
My car is a BEAST in the twisties. Still there's understeer but that's due to my 17" front wheels & 18" rears. our 4-gen f-bodies handle much better with same sized tires and wheels on all 4 corners.
Anyway, my car is lowered, aftermarket front BBK, definitely much more modified than most of the other suspensions out there but let me tell you that the car in the city has a nice firm but comfy and not spine compressing characteristics AND when pushed hard my car handles and tends to shock everybody with it's handling prowess.
Much more comfortable driving around the city than the deCarbons could ever be.
the Koni SA's not adjusted feel like the Bilstein HD's but once you start adjusting them and adjusting them correctly you will have a car that will handle better than your driving skills can handle.
End of rant.
Oh...
In hindsight I should've just gotten Sam's springs in the first place, the GC Coilover kit wasn't necessary for my applications...but I like the fact that I can adjust the ride height anytime I want to...AND, I've adjusted the ride height only twice since 2005.
I took the car out the other day at lunch.... just couldn't wait for the alignment.... and it was very solid and quiet when hitting bumps etc. I got it up to 65mph and it did really well... I guess I got it pretty close when putting it back together... I cant wait until tomorrow after the alignment!!
Gotta get my Str.ts in...
I figured these guys knew what they were talking about...but in reality it was their opinion based on what they EXPERIENCED so as far as they were concerned it was the right choice so I figured who am I to argue?
I should have argued LOL!!!
I hsd the Bilstein's, the KYB AGX's, and the Tokiko's on my 93 as well as the factoey decarbons and really, only the Bilstein's were decent compared to the other two and ONLY if they were on factory springs...but all were better than the decarbons, and all three aftermarket shocks blew out in about 20K miles due to them not designed for lowered springed f-bodies.
again, this was my experience and I'm sure glad I decided to get off of my *** and talk to Sam once I got my 01SS.
good luck with whatever you decide to do!
