Eibach/slp blue springs questions
My questions is how is the Ride Quality with those eibach/slp blue springs one over the eibach pro kit? Cuz I if they ride better I might switch to them. And if you have them on your car post pics thanks I need info
SLP Eibachs and 1LE are two completely different sets of springs. SLP Eibachs came in different versions.
SLP Level 1 Progressive was similar in spring rate to Eibach Prokit but only lowered the car .75".
SLP Level 2 Progressive was similar in spring rate to Eibach Prokit in front but stiffer in the rear and only lowered the car .5".
If im not mistaken the SLP Eibachs that SLP still sells are the Level 1 which aren't much better spring rate wise than the Prokit you already have... however ride quality may improve from not being as low.
If you really want improved ride while still being lowered get BMR, Strano, or Hotchkis.
