vibration at speed
Old Oct 8, 2014 | 05:56 PM
brianbythebeach's Avatar
Default vibration at speed
I have a 98 v6 Camaro, 150k. I get a vibration that can feel at lower speeds (40ish) and is real bad 70-75. done a few things, just cant pin it down. hate to keep guessing(throwing money at it) any help?
Old Oct 8, 2014 | 06:52 PM
new tires, new driveshaft, new rotors, new front wheel bearing assembly. few other things. seems to come from the rear
Old Oct 8, 2014 | 07:03 PM
JOHNNYMO's Avatar
Bent rim? Bent axle? Wheels the stock ones or something aftermarket?
Old Oct 8, 2014 | 07:09 PM
JOHNNYMO's Avatar
Check this out.....
https://ls1tech.com/forums/suspensio...ight-rear.html
Old Oct 8, 2014 | 07:10 PM
Corvett z07's Avatar
Is it like your passengers seat is trying to free itself kind of a vibration? Or more of a slighter vibration?
Old Oct 8, 2014 | 07:26 PM
sleepinghawk's Avatar
With my other 02 trans am, at 55 it would shake right much. Lower speeds wasn't really noticeable. Ended up being the wheels were out of balance.
Old Oct 8, 2014 | 09:25 PM
Default all stock
have the 55 tire package on it, brand new tires all around
Old Oct 8, 2014 | 09:28 PM
don't know about bent rim the wheels have been balanced 3 times since I got them
Old Oct 9, 2014 | 12:37 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Sounds like another case of incorrect pinion angle causing a driveline vibration. Is the car lowered?
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Oct 9, 2014 | 04:46 PM
not lowered
Old Oct 9, 2014 | 06:31 PM
Hmm with it being at 150k miles your bushings shouldn't be worn to the point of them causing the vibration. And you've got new brakes and rotors and etc...
Alright try this: push on the rear of your car, just not on the spoiler, and see if it dips down a lot and count how many times it bounces before settling.
Old Oct 9, 2014 | 09:42 PM
put new monrore shocks in rear 20k ago. I really need help on this
Old Oct 9, 2014 | 09:46 PM
Did you say Monroe? As in Monroe SensaTracs??
Old Oct 10, 2014 | 07:14 AM
yes, I think they were
Old Oct 10, 2014 | 07:26 PM
Alright I'm not saying that this is your problem but can you do that one test that I told you about and see how far the rear end of your car squats
Old Oct 10, 2014 | 07:50 PM
I probably should explain myself
I bought my car with Monroe SensaTracs only on the rear with stock shocks in the front 2 years ago and it shook horrible from 65-73ish. I still don't know how many miles were on the shocks but I could not figure out why my car shook so bad. After throwing a little money at it, I replaced my rear shocks and my vibration was no more.
I replaced my rear sway bar, rear lower control arms, panhard bar, tie rods, and gave my car a tune-up and still my car vibrated horrible. Again I'm not saying it's your problem, but it'll give you something to think about.
Old Oct 10, 2014 | 11:13 PM
I might try that. what shocks did you get? should I get new bushings or look for anything else while doing the shocks? I am so tired of dealing with this. many have drove or rode in my car and not a clue to the cause. two of them ase certified mechanics, both of them said road force balance. I have done the road force balance, still there. I still love to drive my car, but this vibration does take a lot of the fun out of it
Old Oct 11, 2014 | 02:11 PM
I know exactly what you mean. I drove my car for fun in the summer but the highways sucked when it would vibrate. The best feeling is finally fixing it and having it finally driving smooth.
I got KYB gas-a-justs. They're alright with a "jarring" type of feel to them when I go over bumps, if you have the money I'd shoot for some Bilsteins. Replacement is fairly easy, not a whole lot to check out in the rear except to make sure everything is bolted up tight, check your sway bar end links, they're right there by the shocks.
Hope this helps
Old Oct 11, 2014 | 10:29 PM
now I am hearing a scrunching sound coming from the right front brake. weird sound. does not seem to affect anything, car dosent pull when I brake or anything
