Uneven rear end
I swapped the rear springs left/right and nothing changed (granted I did this some time ago), and played with the adjustable panhard rod. I also removed the top spring isolator and did the heater hose mod to the drivers side while keeping the passenger side isolator in and putting heater hose on that spring in hopes of that dropping the drivers side & raising the passenger side simultaneously would get it close. .... no dice.
One odd thing I noticed under the car is that the upper panhard bar -not the aftermarket one - but the stamped OEM one above it seems to have a bend in it on the passenger side of it. Do these things bend or flex over time and looking at how it mounts with the 3 bolts on one side & the single through bolt on the pass side above the PHR.... how can that thing even bend without that whole part of the car deforming?
I'm out of ideas.
Regardless of this, I'm ordering new LCA's and adjustable PHR from BMR tomorrow and contemplating their rear springs as well. All the current suspension mods are greater than 10 years old at this point.
After doing this, this is where the rear is at-- Following the centerline of the wheel up from the ground, the drivers side fender is at 27 3/8" and the passenger side fender is 26 1/4". That's over an inch of difference still.
Any ideas? Here's some pics. The spring pic is the pass side & you can see the heater hose in the isolator.
I know that's probably not your whole issue here but you're going to get some flak on that right there I can almost guarantee it
That is a pretty large variance from your left and right side tho
I'm out of ideas other than when you sit in it, it would level out some but not completely and it should sit better than that with no one in the car anyways
Which direction are both the L & R lower spring pigtails ends pointing....?
BTW, you can also get a set of Hotchkis rear springs. They'll sit slightly higher and are slightly softer than the BMR rear springs.
I'll find someone to simulate my weight & I'm sold on the BMR's, especially on how the car gets driven
Can the shocks be part of the cause? I have older non-adj KYB's. Those will be replaced by s/a Konis
No, the rear shocks play no part in ride height.
I hate to say it, but it's fairly normal for the right rear to sit lower than the drivers side rear, but with it being a full 1" there's the possibility there's other factors contributing to it.
Please correct me if I'm wrong, but if the driver side front sits high, then passenger side rear would sit lower.
That is correct a sagging front passenger side would raise drivers rear & visa versa.
Another thing that I'm going to look at are the rear spring perches. While ordering brakes from Sam Strano today he suggested one may be deformed / bent.
This is definitely an interesting problem and Eric and others, thanks for the help with this!
IMO, that's lower than most lowering springs.
Since the front is even from side-to-side I'd go back to focusing on the rear.
Those are Sportlines and the 2 new rear BMRs will be arriving early next week. I'm thinking also the front is OK.
What I did just now was remove both rear springs -undid the heater hose mod, swapped left & right springs, re-installed both upper and lower spring isolators only. Did a couple mile test drive to let things settle and then remeasured all 4 corners and the fronts are still 25.5" and still 1" higher on drivers side. Driver-27 1/8" ; pass 26 1/8".
IMO, if you can find a way (without cutting the driver side spring) to get the ride height variation within 1/2", try to be happy and live with it.
BTW, did you check the rear ride height variation with your weight or a close equivalent in the DR seat?
Added to the list..... BMR subframes!
Please up date us with the after repair results.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
