shocks/springs question
Parts are like pills. They have a job to do, if you aren't sick you should not be taking pills. If the car has an issue that is addressed by certain parts, GREAT. But just having a car doesn't mean you have the issues to start with!
This is what gets me in trouble a lot and why I will never be a rich man. I sell parts, but I am more worried about selling the stuff folks need than what they want. I know it's crazy but some part of me still believes that's the right thing to do. Maybe not the smartest, but the right thing.
I sell all the parts anyone else does. In fact I have more access to more parts than about anyone else on the sponsor side of things (even including some from companies you might be surprised I can do). Doesn't mean I think all those parts are warranted.
Next up is a differential and better pads.
Since getting into handling they have been adjusted up a hole to make the arms more parallel while sitting still. I can't speak for the difference it made since I was quite new to learning the cars capabilities during autocross.
Anything I see/hear about it is having the LCA's angle down is more for drag racing and parallel is more for handling.
I'm not going to tell you NOT to run LCA brackets and the like. I sell them, I sell them because there are times they are a something we want to add. But I'm also not going to blow smoke up your skirt that you have to have them just because you lowered the car. And the "geometry change" argument is kind of amusing to me. Those that say that are all about it... and for years have run panhard bars which do odd geometry things in general vs. a Watts link too. But only until we've had and been using Watts links have you see anyone else even care about that, and start to copy that thinking.
IMO you would have to really learn the car for a while and then do nothing but add relocation brackets to be ale to tell. I have become an advocate of "don't buy something unless you need it".
Every mod I have done to my car has been because I drove the car hard enough at autocross to find it's weak points. In which case I would upgrade to "fix it".
If the car will be a true DD with the occasional back road curvy sprints then simple shocks/springs will go a long way with an adj PHB. Then add sway bars on top of that if you are not happy. Anything more IMO is buying parts just to buy parts. Meaning not buying relocation brackets, SFC's, T/A, T/A relocation bracket, tubular rear LCA's etc etc.
Depends on what you want the car to do. IMO don't bother with HP mods until you can tame the current HP level around a turn. I was in the same boat wanting a cam until I got on a autocross course and I was slapped in the face with reality. Learn to drive FIRST then upgrade things that need upgrading.
I won't touch my motor for a WHILE. More HP won't help you if the suspension is not up to par or you don't know how to use it. You can get in trouble real quick lol. Hell I can get in trouble with only 311/346 at the wheel.
Frankly I never wanted for a much more power than my Z28 made with a good tune, light flywheel, headers. And if I had 3.73's it'd have been more than enough. I think it's a function of where you live and drive. I actually have more fun day to day in my 2000 FRC than my 2007 Z06 because the Z06 is just too much for pounding around in. I know it sounds silly but more isn't always more.
BTW though you don't see it on my website (because I'm too busy) I can do things like heads and cams too. Anything you find at someplace like Jegs or Summit, I can do too!!!
