Wilwood 4 Wheel Big Brake Kit with BS Street Lites?
I have the templates for these and need to pull my wheels to verify. Unfortunately, the templates don't give you dimensions for the hub to caliper length and therefore, the spoke face clearance.
But I was wondering if anyone has used the Wilwood 140-9833 kit in the front (13.06" rotors with SL6 calipers) and the 140-9830 kit in the rear (12.88" rotors and SL4 calipers) with the Billet Specialties wheels or maybe TTIIs since they are also very tight on the caliper?
They seem to be pretty narrow and the BS Street Lites barely clear the stock calipers. If the Wilwoods are bigger than them, then I'm SOL without a spacer. Does anybody know if the Wilwoods are the same size as the stock PBR brakes?
Has anyone run them with BS Street Lites or TTIIs?
This should have all the dimensions you need. let us know if there is anything else we can help with.
http://www.wilwood.com/PDF/DataSheets/ds566.pdf
