2001 Camaro SS Ssteering has a "catch" in it when turning the wheel
Ok, so I recently did a motor swap on my 2001 Camaro, and now when I turn the steering wheel it has a "catch" it it. It's like it's binding up and then releases, then binds up, then releases while you're turning the wheels lock to lock. I've attempted adjusting the steering linkage that connects the column to the rack several times to see if I had it down to far or up to far on the steering column shaft. It almost seems like one of the u-joints is binding up in the steering linkage. Has anyone ever heard of anything like that?
This is an LS1 car, so now rag joint in the linkage. It feels like something mechanical binding up for sure. I didn't disconnect the power steering lines, so I don't think there is air in the power steering pump.
Any suggestions? This is driving me nuts.
LS1TECH Sponsor
Steering shaft dragging a header tube? Seen that happen before, especially with stock motor mounts.
__________________
Would it put the suspension in a bind at all if I torqued the shock tower bolts down while the suspension was unloaded? I read something on another site that mentioned that. Didn't make much sense to me, but I figured I'd ask.
I know my ball joints, etc are pretty shot, but I would think they would have bound up before if that's all it was.
LS1TECH Sponsor
But when does it happen. I had it happen on my car only when pretty hard on the gas and with a little steering in. Any other time the engine didn't move up enough to contact and the steering shaft was turns so as not to hit. This was with 1.75" headers too.
I still think this might be it because in your response you say "new" headers.
And fwiw, I do more than suspension.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
__________________
Gotcha, ill check it out then for sure today if I get home before dark. Ill follow up and tell whether that's what is causing it. Any fix at all for it, or do you just havd to deal with it?
