BMR torque arm problem and solution
Old Nov 29, 2014 | 10:33 AM
LSGUN01's Avatar
Default BMR torque arm problem and solution
Hey guys, I used the forum search to get some good info on the bmr torque arms. I was driving home the other night on the highway and heard a pop and my car started to vibrate worse when at higher speeds. When shifting from 3rd or 4th it was pretty clear that something had come loose. I put it on the lift and discovered that the shackle that mounts to the transmission had come loose and the bolt was gone...or so I thought. Luckily when I took the cross member off to get a closer look my missing bolt fell out of it and onto my foot. Anyway, re-torqued everything and put it all back and problem solved. Feeling very relieved about this and not having something like a clutch or tranny issue.
