aftermarket upper and lower control arms on stock k member
Probably a dumb question. Did some searching and can not find answer....is it a good idea to run after market upper and lower control arms such as umi,bmr etc with a stock k member or is it a better idea to wait till the after market k member is installed? Has anyone run them on stock k member?
Thanks
Thanks
well the uppers don't matter at all because they don't come in contact with the k-member at all, the only reason to wait is because after installing the lowers you will need to have the front end aligned and it doesn't make sense to pay for an alignment that will have to be redone in a few months when you add the k-member.
