question on drag shocks ?????????
Old Dec 9, 2014 | 07:00 PM
ironmikektm525's Avatar
Default question on drag shocks ?????????
My rear shocks are worn and I was doing some research on drag shocks( I don't know much about them). Seems like best bang for the buck are ce2700's and summit racing g7700. Just looking for little better traction(transfer) as I need to buy shocks anyway. My t/a has full boltons/ BMR suspension package(new era)stock springs(heater hose mod). I don't want to run drag radials as I drive a lot of miles. Ran a 13.9(a4 /3:42) with crappy 2.2 60ft. Question is how do these handle on the street/corners/ect? Will these make any sort of traction improvement? Your thoughts ? These part #'s are correct right? Thx
Old Dec 9, 2014 | 08:18 PM
RobsZ28's Avatar
Rear drag shocks only I don't think make a difference in weight transfer. At one point I had Strange double adjustable shocks on my car. Rear only, I didn't notice a difference between them and stock rear shocks in road handling and track times. Because of have stock struts and the front sway bar connected the car wouldn't maintain the weight transfer, the front end would come up and go right back down.
Old Dec 9, 2014 | 08:31 PM
Do they wear out quicker then stockers ? I put on miles during the summer
Old Dec 9, 2014 | 08:46 PM
Rise of the Phoenix's Avatar
I'd start with a good double adjustable coilover for the fronts and then work your way toward the rear. Viking coilovers seem to be the best bang for the buck. Get yourself a set for the front and then run those drag shocks in the rear, or put on the Viking double adjustable rear coilovers and have yourself on hell of a hooking badtard.
Old Dec 10, 2014 | 11:04 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
^^^ This.
Give us a call, we can go over your combination and set you up with the right shocks and springs to make your car work very well on both street and strip. You have to be careful on what you purchase as it may not work that well, or possibly be worse than what you already have!
Old Dec 15, 2014 | 04:57 PM
Think I'm going with ce 2700.
Old Dec 16, 2014 | 09:10 AM
transam69230's Avatar
Everyone on this board will tell you that is a mistake, but it is your money.
Old Dec 16, 2014 | 10:32 AM
01ssreda4's Avatar
Good job! You listen to advice well.
Old Dec 18, 2014 | 07:28 PM
Sladester2's Avatar
the shocks work well, do a search, many have used them for drag racing.
Old Dec 19, 2014 | 10:30 AM
BMR Sales2's Avatar
The Competition Engineering 2700 drag shocks definitely aren't the best ones out there but I have had some luck with them and have gone some mid 1.3X 60ft times on them with a well set up car.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
