Problems with 01 Trans Am WS6
And I recently replace the Shocks and Springs
the springs I went ahead and got Eibach Pro-Kit Lowering Springs.
Lowers Vehicle up to 1.5" so they say so after that and some other things I had replaced I took It in for an alignment because Its all over the road not pulling a certain way just all over the road like one little bump its that way you know. so anyhow I took It In for an alignment and they guys said they did the best they could to get in it in the ball park but its still off they said I needed aftermarket parts for the upper control arm since I lowered It so much. so therefore would like to know y'all's thoughts about It. and If you had any links to any parts I may need to get that would be very helpful
Thanks,
Brandon
Thanks,
Brandon
Also what type of shocks?
Ditch the Eibachs and get some good springs...
Thanks,
Brandon
Easy fix is the MWC full adjustable uppers and then a set of rear adjustable lowers, relocation brackets, and Panhard bar. Cost isn't too bad right now with all parts on sale and you will have a full adjustable alignment for both ends.
Give us a call... we have a great price on these items right now and expert tech help to get you all set up!
